Open Source Code
Open Source Code public repository is available at: https://smath.com/svn/public
Getting files from public repository¶
Instructions for obtaining the source code of open extensions on Windows OS:
- Download SVN client from https://tortoisesvn.net/
- Install the downloaded program (you may need to restart).
- Create a folder on your PC where you want to store the sources.
- Right-click on the created folder and select "SVN Checkout..." from the folder context menu.
- Fill in the text fields in the dialog box that appears (usually only the repository URL is required) and click OK.
- Available files will be downloaded.
Obtaining write access¶
To obtain write access to the public SVN repository please contact support@smath.com.
Repository Sections¶
- Handbooks - mathematical guides and e-books.
- Integration - examples of integrating SMath Studio with other applications.
- Plugins - SMath Studio Plugins sources.
