Description Function
description(parameter) returns the description text of the definition parameter, using the current language.
parameter can be a built-in or user-defined variable, function, or unit.
Syntax¶
If parameter is a built-in function, constant, or unit, description() returns the built-in description.
If parameter is a user-defined function, variable, or unit, description() returns the user-defined description.
If the user-defined description has multiple lines, description() returns the description as a single-line string.
If the user-defined description is not set, description() returns an empty string or a zero value.
For more on documenting your worksheet with descriptions, see Descriptions.
See also¶
This page is based on a legacy wiki article by Davide Carpi.
