Skip to content
Local Licensing Server Initial Setup
The first steps after installing the Local Licensing Server: open its management console, sign in and change the default password. Then load your licenses.
This page describes Local Licensing Server 5.1. For version 4.2 and earlier the details may differ — see the delivery instruction for version 4.2 (PDF).
Opening the console
On the server machine, open a web browser and go to http://localhost. If you changed the default HTTP port 80 in docker-compose.yml, add your port: http://localhost:8080.
You can also configure the server from any other device in the same local network: use the server's IP address with the port, http://<server IP address>:<port>. Make sure the server's firewall allows access to that port.
the server's Login Form
Signing in for the first time
Sign in with the default credentials given in your delivery instruction. The portal does not publish them: a server whose password was never changed would be open to anyone who read it here.
The server asks you to set a new password straight away. Keep it in a safe place — if it is lost, the only way back is recreating the database.
the Update Password Form with the admin account
After the password is changed, the Licenses page opens. This is where the rest of the setup happens:
the Licenses page: connection to the licenses source, network address of the local server and account details
Continue with Loading Licenses.
