Skip to content
Installing the Local Licensing Server
How to deploy the Local Licensing Server on a Docker host. Check the system requirements first; after installation, continue with the initial setup. Updating to a new server version follows the same steps — see Updating the Local Licensing Server.
This page describes Local Licensing Server 5.1. For version 4.2 and earlier the details may differ — see the delivery instruction for version 4.2 (PDF).
The delivery package
An installation package is prepared for your organization after the agreement is signed. It is unique to your organization and intended for a single legal entity only — do not publish it. Your software vendor tells you where to download it; the download may require authentication with the data from your electronic license document.
Extract the downloaded archive to a local disk — not to a network share or a mapped drive — and perform all further steps in that folder. It contains two files:
the extracted package: docker-compose.yml and the image archive
  • docker-compose.yml — the Docker configuration, a text file;
  • a .tar archive with the Docker images.
Both can be used unchanged if the default configuration suits you.
Loading the images
Make sure Docker and Docker Compose are installed and working. Open a terminal in the folder with the extracted files and import the images into Docker:
docker image load -i <image archive>.tar
the docker image load command in a terminal
Choosing the ports
docker-compose.yml defines two external ports you may change if they are already taken on the host:
  • HTTP port 80 — the server's web pages;
  • HTTPS port 443 — protected connections from SMath software.
If you change them, open the new ports in the firewall instead (Network).
Starting the server
docker compose up -d
When the command succeeds, Docker starts the server's containers:
docker compose up -d creating the network, the volume and the smath-db, smath-init and smath-app containers
Container What it is
smath-app The main application with the system's business logic. It writes its logs as described in Accessing Local Licensing Server Logs.
smath-db The database management system.
smath-init A tool for the initial setup of the environment; it exits once it is done.
The server is now running. Open its web pages to complete the initial setup.
Using your own SSL certificate
The server can use your organization's own SSL certificate for its HTTPS connections. You need two files:
  • server-ssl.key — the private key;
  • server-ssl.pem — the certificate chain.
If your certificate file has the .crt extension, just rename it to .pem.
  1. If the server is running, stop it. In the folder with docker-compose.yml, run:
    docker compose down
  2. In the same folder, create a folder named certs and put server-ssl.key and server-ssl.pem into it.
  3. In docker-compose.yml, find the volumes list of the smath-app service and add the line - ./certs:/app/certs to it. This mounts the certs folder into the server at /app/certs:
    services:
      smath-app:
        volumes:
          - data-protection-keys-XXX:/root/.aspnet/DataProtection-Keys
    Here XXX is your company identifier. Leave the existing line as it is.
  4. Start the server again from the folder with docker-compose.yml:
