Local Licensing Server
Introduction¶
By default SMath licensing system supposes SMath Studio is getting your license details from SMath Root Licensing Server at smath.com. Usually it is convenient for the individuals and some small companies. But it causes a number of artificial constraints for the commercial customers:
- Permanent Internet connection to the Root Licensing Server is needed from all machines where SMath Studio is used.
- In order to manage your company users you need to register them on smath.com.
- You manage your license bindings via your software vendor.
In order to address all these issues and provide a platform for future organizations related improvements Local Licensing Server has been created.
Interaction Scheme¶
All interactions between client and server products happen over TCP/IP using HTTPS (HTTP is also possible within a local network).
Note that starting with Local Licensing Server version 5.1, its Online communications with the Root Licensing Server happen over port 443.
Features¶
- User friendly interface available in your favorite browser.
- It still needs an access to Root Licensing Server, but it is enough if it happens once a day. It means short-time Internet related issues does not affect end users at all.
- Full offline mode is also supported.
- You manage your users locally. Only single account for your company is needed on smath.com in order your server would be able to get license info from the Root.
- It is your choice to manage your users name by name or to provide anonymous access for them in order to stop handling all those forgotten passwords at all.
- You get a chance to monitor who is using what licenses right now. If you purchased Floating licenses it may show you who locked the license for example.
- Compact installation package — about 330 MB to download.
- Driven by Docker technology and may be easily installed on any Operating System just in a few minutes.
- May be moved to another IP address, another port, another machine in your network any moment without involving your software vendor at all.
- Adding new license(s), changing or prolonging it does not require Server recreation/reinstallation or SMath Studio reinstallation.
- Both Fixed and Floating licenses supported. If you are not satisfied by Local Licensing Server for any reason, all your licenses always may be moved to the Root Licensing Server or vice versa by your software vendor.
- SMath Studio Enterprise may use both Root and Local Licensing Server if required.
- A local SMath Studio Cloud can be included in the server delivery.
- You are getting it for free when buying at least 5 any SMath licenses.
- More nice features are coming soon.
Setting up the server¶
The following pages describe Local Licensing Server 5.1. For version 4.2 and earlier the details may differ — see the delivery instruction for version 4.2 (PDF).
- System Requirements — hardware, software, network, system time.
- Installation — loading the Docker images, starting the server and installing your own SSL certificate.
- Initial Setup — first sign-in and the default password.
- Loading Licenses — online, or offline with a license package.
- Authentication Modes — anonymous access, accounts created by the administrator, self-registration.
- License Reservation — how fixed and floating licenses are reserved.
On the workstations, install SMath Studio Enterprise and connect it to the server.
Maintenance and troubleshooting¶
- License Obtaining Challenges — the usual errors and how to resolve them.
- Updating the Local Licensing Server — free updates to a new server version, and how long older versions are supported.
- Accessing Local Licensing Server Logs — where the server writes its logs.
- Recreating SMath Database — when the admin password is lost or the data is inconsistent.
Support¶
Your License Holder receives the delivery package and its instruction from your software vendor after purchase. Our technical specialists are always ready to assist you with the server as a standard part of SMath infrastructure; to diagnose an issue yourself first, start with the pages above.
Limitations¶
At the moment only commercial customers may purchase Local Licensing Server.
