Offline Mode
Introduction¶
By default all SMath licenses require permanent Internet connection to a Licensing Server. It is related to both Root Licensing Server and Local Licensing Server. We traditionally recommend accepting it, as it is needed not only for getting license specific information, but also for downloading plugins and some other things, handled remotely. If your business needs still require you to work without a permanent Internet connection (for example, if you are a field engineer without any access to the network), you may temporarily put your license into Offline Mode. It will let you continue working with SMath Studio without any annoying reminders. We just do not recommend staying in this mode for long, since licenses in Offline Mode have a number of significant limitations.
Switching SMath Studio to Offline Mode¶
Important note: If you are connected to the Local Licensing Server, you may not put your individual SMath Studio to Offline Mode. If you try to perform it as described below, it may cause you to start receiving a free license instead of your purchased commercial one.
In order to perform switching your SMath Studio to Offline Mode you need to perform the following steps:
- Open your SMath Studio, perform Logout if you are already logged in and open Login dialog over again.
- Click Offline Activation button.
- Use your smartphone for scanning shown QR-Code and navigating to the Offline Activation of Program page on our website.
- On the opened Offline Activation of Program page select desired Offline period. We strongly recommend selecting as short a period as possible.
- After all the settings are selected, press Activate license button and save Offline package file.
- Go back to your SMath Studio and load this Offline package file by clicking Select license file to activate... button.
- Make sure the file was accepted and your SMath Studio showed your Offline license properties.
If you cannot use your smartphone or the QR-Code did not work for any reason, you may get your Offline package manually inputting necessary data:
- Login to your Profile page. Make sure proper SMath account is in use if you have more than one.
- Go to the My Licenses link to open the page, listing your available licenses.
- In the upper page part locate the grid, listing your available licenses and click the link Offline Activation of Program above it.
- Go back to your SMath Studio and click the button Other options to activate under QR-Code.
- Select the license you want to switch to Offline Mode, copy your Device ID and Program Version from SMath Studio dialog to the appropriate field of Offline Activation of Program page on our website.
- Remaining steps are the same as described above for the QR-Code scenario.
Switching Local Licensing Server to Offline Mode¶
A Local Licensing Server can work without internet access too. Since version 5.1 you obtain its offline license package yourself, through a request file and the offline activation page on smath.com, and renew it every year. The procedure is described in Loading Licenses.
